Install Wire SlingMods LED Driving Light Bar?
JimboRTS
Need help installing SlingMods LED Driving Light Bar on 2021 RTL. I can’t figure out where the power wire goes under the frunk to the lift bar. I have tried a flash light and a wire fish. Watched the video on Utube and read the instruction that came with but still can’t figure it out. Any comments welcome.
Jim
SlingMods
:chat: Check with the seller if they have any help tips.
Also Check if there is anything else on U-Tube.
I am sure someone will come to your aid very soon.....:thumbup:
If it's similar to my F3S, you pull the frunk (remove the 4 push pins) and look for the accessory wire located near the battery. They should be tagged with a white label stating accessory.
A link to exactly what you're installing would help. If it's the very bottom light in the middle when you remove the plate the wire should be plugged into the back of it. At least it was on my 2020 RTL
I’m installing the SlingMods LED Driving Light Bar on a 2021 RTL that mounts in the middle front. I can’t find where to run the wire (red and yellow plug wire) from the switch to the light. It’s all enclosed and I can’t see where to run the wire
Jim
I’m going to jack the front up so I can get under and maybe see where wires go. Can’t do it until tomorrow. Will post a follow up tomorrow.
Jim
That's the one I was thinking of. So when you removed the plastic plate nothing was attached to it? More than likely when the bike was assembled someone forgot to plug the wire into the plate. It should be just hanging around in there somewhere.
Got the light bar installed. 2 person job, one to shine flash light through the routing hole other person on the back side to see where light showed. Than put finger in hole and other person could see where the wire need to be routed.. than ran wire and attached to wire fish to pull through.
Jim
