Instrument Panel Gauges ~wavy~
elkk
The black background on my Instrument Panel Gauges is kind of wavy. Take a look at the speedo between 90 and 130 you can see it, both the speedo and the tach are having the same issue. Is there a way to flatten these out? Is the material coming loose? I bought this Spyder from a friend and he never rode in the rain and never hosed it down. Just wondering if it can be fixed easily, it's starting to bother me a bit.
Tough one..!!
popping the cluster out is easy. You can get replacement lens and seals but don't know about replacement dials. Hard to tell from the photos just what is going on. Some clusters did get moisture in them but mostly left streaks. I have the needles fading from the sun but the dials are fine...you could check with your dealer but if it does not block the needle sweep you may have to live with it...like the pretty pink needles..:roflblack:
Best guess is the clear plastic is warping from direct sun & or heat. Swing by dealer ask tech to take a peek. Hope all works out.
