ipod Lead for RT - S
eddieshep999
Does anyone know if the Supplied ipod lead also charges up an ipod when its connected or does it just output Audio to the Aux Part of the Radio system
I am considering replacing my existing MP3 Player (Non ipod) as the only control I have using the 3.5 mm jack lead only allows volume to be changed from the RECC -
(ROADSTER ELECTRONIC COMMAND CENTER) Handlebar controller
I would need to charge up my MP3 Player by using the 12v power supply in the rear trunk
At least with an ipod connected using the ipod lead I can also change tracks, albums etc
Thanks
Eddie Sheppard
thats right - but did they change now the socket to the front ? or are there two of them now ? (pic from BRP)
Chris
Your picture is for the Helmet Comm connection for the driver.
The IPod is still connected via the Jack on the right hand side of the rear trunk. Once the IPod is connected one has full control of the IPod from The RECC and it stays fully charged.
Doc
thanks - we don`t have that here in europe (both helmets = bluetooth)
chris
Question: My MP3 player (not an I-Pod...) doesn't hook up to the supplied cable that hooks into the RT's stereo system. Does BRP have adapter plugs, or is this going to require a trip to Radio Shack? My player has a cable that plugs into it and terminates in a USB plug at the far end...
The only BRP-supplied cable for a non-iPod player is the one that ends in a headphone jack at one end and fits the RT's socket at the other. THis means you can listen to a pre-set series of songs, audiobooks, etc. but cannot control them while underway. You also have to have a separate charging ability if your trip will last longer than your device's charge.
I've used the supplied cable for my XM Radio and my GPS, and it worked well with both. Oddly enough, it's not long enough for a small device to rest on the floor of the trunk, so you may have to have something to support your device unless it's very light. I have a cigarette lighter adapter that has three outlets and a USB power point, so I haven't had any charging difficulties, either.
It would have been great to have had a greater range of supported devices, but I doubt any of us would have wanted to pay more of a premium to get someone else's device supported. I think all the iPod users owe me 15 cents, since integration of their device made my machine more costly...
I guess that I'm going to have to take a trip to Radio Shack then with the BRP cable in one hand, my MP3 player cable in the other, and see if there's anybody working there who can match them up... :cus: I'll let you know if I find anything!
There should be an adapter that plugs into the port in the trunk for a 3.5mm male plug. Male to male cable is needed to plug your mp3 player in. I drilled a small hole in the back of the trunk and ran a 6 ft long cable from the back up under the seat to the front where I can plug in my cell phone, mp3 player or anything else with a 3.5mm receptacle. Not fancy, not pretty, but it works.
I used self sticking velcro on the ledge toward the top of the trunk to hold the iPod and any other small items such as a accurate air gauge that you want quick easy access to.:D
Rudy
MP3 Connection
I just purchased a cable, BRP Dealer Part #710001406 SD 1HP Audio Plug(Not a USB) that plugs into the 7 Pin outlet in the trunk and and has a MP3 male terminal to plug into the MP3 player. The audio comes from the AUX outlet(and allows volume control only) from the handle bar controls. If you buy a longer cable(5 to 6 feet) and connect to the trunk cable BRP Dealer Part#710001406 and then run the new cable(5-6ft) under the seat to the handlebars and attach the MP3 with velcro, you are then able to change selections while riding.
The IPOD cable allows you to play a IPOD with your IPOD controls that are built into the instrument panel mode, and also allows you to view the album and song title.
Hopefully helpful,
SpyderBen
Is that a Radio Shack part number? (Sorry! I'm just extra-ignorant on things like this!):D
It is the BRP number for the 3.5 mm adapter cable. If you bought an RTS, you should already have this cable. One end fits the Spyder, the other end has a male 3.5 mm stereo headphone plug to attach to your device (or to an extender cable).
I have been using my iPhone connected via the ipod connector in the trunk. My question is, has anyone tried using online radio (Pandora, Sirius,etc) with this connection. I have an issue with the music switching from the online service back to the iTunes/ipod music stored on the iPhone everytime I restart the Spyder.:dontknow:
I have my XM radio connected to the MP3 cable. It does not allow me to change the station. I plan to run another cable under the seat to the handlebars. I am having a holder, designed to attach to the handlebars, produced this weekend for the radio to allow me to be able to change stations and also a power source to cut he power off and on when the ignition is turned off/on.
Yup, I decided to do that also. Bought most of the parts today. I found a panel mount 3.5mm jack to install up front that is weatherproof. I'll just keep my iPhone up front I guess. Also have a RAM mount so I could plug my Garmin in there too. Thanks for the reply.
Hey DaBusses, I have tried it with Pandora and it works good as long as you are in a 3g area. Haven't tried it long enough to see if it switches back to the IPod as we ran out of the 3g area and I went back to the IPod myself. I think Lamont has a video on using Pandora.
Getting my RT back tomorrow...:yes:
Got my issues worked out now. Installed a panel mount 3.5mm jack where headset jack would be on switch panel, RAM ball mount to mount either my Garmin 660, iPhone, or HD video camera on the handle bars. Now I simply use controls on the device that I am listening to instead of Spyder hand controls. Works great, can use GPS ap and my choice of music while multitasking on the iphone. Probably won't use the Garmin much. I use Navigon GPS on the iphone and it works great. Up to date all the time.
[ame]http://www.youtube.com/watch?v=QI7HbZQalz4[/ame]
