fastfraser
Blazing Member
Hi All I'm installing the DCPR8 Iridium plugs in my 2011 RTS and just want to check the gap to be sure its right . Anyone know the correct gap ?:dontknow:
If you're gapping true Iridium spark plugs do not use a standard gap tool. The Iridium center electrode is very hard, and very brittle. If you put any pressure on it you will fracture it for sure.
This is the kind of tool I prefer.
Correct gap in English units is 0.028" - 0.031".
Thanks Ron & Scotty
I don't plan on re-gapping the plugs but because they have sat for a bit on my work bench, I just want to make sure the gap is correct before the install .
What am I.. The Answer Man!? You're supposed to be bugging Scotty for this follow up stuff.
I tell most people to just install the Iridium plugs I sell with the gap they come with to avoid breaking the center electrode.
But here are 2 good tools for adjusting the gap on Iridium spark plugs. Of course they will work on most any adjustable gap plugs as well. As long as you are careful, either will work well. The Iridium center is fragile. Once you fracture it, even the slightest bit, that plug is done.
If you're going to adjust your spark plug I recommend .8mm or .032"
This is what NGK says;
"The re-gapping of fine wire spark plugs that have very small diameter platinum or iridium alloy electrodes is not recommended due to the risk of damaging the electrodes. Virtually all NGK spark plugs are set to the correct gap for the catalogue applications at the point of manufacture."
This is the Correct way to do it
This is the WRONG way to do it.
This is what you ABSOLUTELY DO NOT WANT TO DO! This is a wedge tool which leverages between the center electrode and the ground electrode. It will break your platinum or iridium plug every time. It works fine for standard center electrode plugs, but you'll be crying in your soup if you do this with an Iridium plug.
Now ask Scotty what the book recommends....hyea:
Sorry, as I know this is an old thread, but Ron, I could’ve sworn that you told me that .034” was a good gap for the 8’s when I bought them last week, so that’s what I did yesterday. I used flat feeler gauges to test adjustments. I’m just confused, because here you’re saying .032”
