2...fuel addition to throttle
3...fuel addition to max throttle
4...fuel addition to cruising (I find this one to really waste fuel)
5...fuel addition timing speed to throttle (how fast the fuel is injected when you throttle)
6...fuel addition timing speed to max throttle
You adjust based on your preferences...
The way I've understood all this I would use a bit different wording:
1...not used
2...fuel addition during acceleration
3...fuel addition during max throttle
4...fuel addition to when cruising (steady throttle)
5...fuel addition timing speed for acceleration (how sensitive/quickly it determines you are accelerating)
6...fuel addition timing speed for max throttle (how sensitive/quickly it determines you are on full throttle)
For 5 & 6 the LOWER the number, the more sensitive it is-- as in it will detect your change from cruising to acceleration or full throttle quicker.
The problem many of us have run into is having 5 & 6 set to the same setting. The system gets confused and doesn't know if you are just accelerating or are on full throttle -- so it has a temporary glitch where it shuts off ALL signals and the engine stalls momentarily :yikes:. Not a fun experience when you're passing someone! The only 'cure' when this happens is to let off the throttle a bit and the engine will kick back in.
JB should have a disclaimer on this situation, or fix it so it won't do this.nojoke
At first the programming is a bit awkward, but you get used to it. Rather than use the 'color scheme' - I just count modes from 1,2,3,etc...... and you have to be kinda quick when doing it.
