BajaRon
Well-known member
Spent 1/2 a day at Lamont's getting the Spyder ready for a quick trip to Washington DC (leaving Friday).
I finally got a New Rear tire! Love the look of that Toyo.
Lamont says now I have to quit whining about him having my tire. Didn't know I was whining. :dontknow: Thought I was just telling it like it is.
I had a bunch of maintenance things that needed to be done since the trip to California.
Oil change. I had 6000 miles on the AmsOil and it still looked pretty good to me. No metal on the magnet. Always like to see that. For some reaon my Spyder takes 4-1/2 qts to fill but Lamont's comes to the same point on his dipstick with just 4 qts. Go figure? :dontknow:
Burnt out tail light got fixed (Lamont did that too since he was in the area doing my rear wheel extraction). Thanks Lamont!
Re-did my crankcase vent catch can. Converted it over to a sight glass with some Uni-Foam. Hooked it back up to the air filter. I like the idea of a little negative pressure to help vent the CC. Just don't like oil in my air box.
Now I can keep an eye on the CC vent situation quite easily. I'll know if oil is getting past the Uni-Foam or not without having to pull the air cleaner. And what oil does come up into the sight glass will go back were it belongs eventually.
I did the Canister-ectomy and ran the fuel tank vent line back along the right side of the fuel tank. That was easy! I didn't do this because I needed to....just wanted to run without that pesky purge valve and evap canister for awhile.
Right away my Spyder was idling way too rich so we set #2 JB down from 6 (where I had it) to 3. That cleared the low end richness up right away. My purge valve must have been allowing air to pass at idle/low speed leaning the mixture. Wasn't giving me any problems before but it was interesting to see the instant change in the way my Spyder reacted.
With the purge valve plugged I was then too rich at idle. The JB is a great little tool for adjusting fuel mix when changes are made. Very quick and easy.
Spyder ran great before and is still running great. Didn't get to ride enough to know if there are any other changes but didn't notice any so far.
It is great to get together with a friend and wrench on your ride. It is one of the things I love most about motorcycles.
Now I just need to mount a RAM to put my Garmin GPS on and I'm hitting the road!
Never been to Washington DC so this will be an adventure for sure. I usually am just fine without a GPS but for this trip I think I can use the help.
Ain't is GREAT to own a Spyder! I always look forward to my next trip because the Spyder makes going anywhere a lot more fun! :yes:
