yamahog
Has anyone looked into or tried something like this on there syder I sure like having it on my car? http://www.digitalguarddawg.com/keyless.htm :spyder:
The DESS should be easy enough to bypass. Just remove the antenna from around the ignition key barrel. Mount it with a programed transponder key glued or taped into it, somewhere under the bodywork. The DESS module wouldn't know the difference.
Have you written them? [email protected]
I figure you could leave that alone and just hide the key some where under the tupperware or does it have to be in the switch to work, not sure about the run stop switch but I figured some one on here would know :chat:
Remember that with the Spyder it is not as simple as merely turning the ignition on and pushing the starter button. You have to turn on the ignition, wait for boot up, push the mode switch, then start the machine. Don't forget about checking the kill switch, either. It should not be disabled for safety reasons. I would doubt your keyless starting module would have the sophisticated programming and multiple outputs to accomplish the entire starting procedure. There is more to it than merely fooling the DESS.
The system the OP is referring to is a keyless ignition system not a remote starter. I agree a remote starter system would bring up a lot of other challenges.
While they do offer the remote starter option that is not what I am after, just the keyless ignition to eliminate having to dig for the key, just get on, flip switch to run, hit mode switch, the start button and go :spyder:
