DickB
Slingmods sells a keyless system by Digital Guard Dawg at $299. But there is a much less expensive alternative. The Digital Guard Dawg M1 works just fine, is easy to install, and can be had for $107 at DennisKirk.
I chose to install it at the starter solenoid. Pull the two-wire plug from the back of the solenoid, cut and connect the violet/blue wire to the Guard Dawg module. Connect red and black Guard Dawg wires to the battery. (I used a separate fused battery connection.) There is a little cubby hole near the fuse box into which the module can be secured with 3M auto trim tape. I applied Liquid Tape to the wire exit to seal against the elements.
Watch the Slingmods video to see what to do with the Can Am RFID key. With either system, the RFID key must be left attached to the bike. I may just leave mine exposed, so it can be easily removed for extra security. Someone could swipe it, so I'll carry the spare with me on the Guard Dawg Tag to keep from being stranded. As is, I often forget to remove the RFID key. Now if I don't the bike still can't be started.
The M1 does not have the bypass switch and code that the Slingmods does, but frankly that seems unnecessary. Slingmods has you locate that switch where the plug-and-play connection is. Once you have access to that area, I'll bet unplugging the module and replugging the stock connectors takes less time than entering a code with a pushbutton switch.
The remote functions just like the Slingmods version. It comes configured in Manual mode, where you must press the remote button to enable starting. It can easily be programmed to Automatic mode, where it just has to be close to the bike.
