Is there plenty of room on the rear RT for the 255 50 15 Kuhmo tire?
you will need a 215x60R15 up front to keep rolling circumference equal for front & rear but i think it may be too squishy for the front
or a 225x55R15 which should work with the nanny but can it fit the front is another question.
Thanks for this information! :thumbup:I am running a 215/60/15 on my 2012 that is 5.4% larger with NO problems. It should reduce your speedo error too.
Mr. Denman is mis-leading about the diameter. Yes it's going to be VERY slightly larger but only because the aspect ratio is changing. The issue you are facing is going to be the tire width in the area of the SWINGARM where the front of that tire is closest to the front of the swingarm. This size is 30mm wider which is over an inch and this might not fit...!!!!!..... Also wider tires will generally HYDRO-PLANE sooner under the same conditions than a narrower tire......Mike :thumbup:Is there plenty of room on the rear RT for the 255 50 15 Kuhmo tire?
Personalization? :dontknow:Why not just buy the Kumho in the OEM size? Why reinvent the wheel.
Is there plenty of room on the rear RT for the 255 50 15 Kuhmo tire?[/QUOT You will have to get KUMHO to make this size for you .......because currently they don't make it now.........The largest 15 inch tire they make is the 225/50-15..................just sayin......Mike :thumbup:
Actually; a 255/45-15 would be less than 1% taller... (+.7%)
(If the width isn't a problem...)
again, who makes it, i always tell people that come in for tire sizes they make up, i require $100k deposit & 1 year to have it made.
