I ran over 20,000 miles on my front tires with very little wear. What wear they had was very uniform. At around 18,000 miles I did get a bit of 'out of balance' cupping on my right front (very hard to see in the early stages) but I look closely at my tire wear fairly often. Tires can give you early warning about suspension problems and other issues.
I put Ride-On in my front tires (already had it in the rear) and the cupping went away. If you catch these things early enough you can save the tire.
Tires can go away in a hurry if there is an alignment problem and I started to get some pretty good wear on the inside portion of the right front. It had to be alignment (too much toe out) and seemed to begin about the time I had the DPS replaced (around 20,000 miles). I coudln't be sure but it was convenient to blame the DPS changeout.
But as I looked into the DPS possibility, I could see no way for a DPS swap to cause an alignment issue. So Lamont and I decided to give my Spyder an alignment before going to CA. When lifted my Spyder we found quite a bit of slop in the wheel, like a bad wheel bearing.
We were were about to inspect the wheel bearing when Lamont said something about the tie rod end. BINGO! The slop was all in the tie rod end. Wheel bearing was fine.
You can't buy just the tie rod end. You have to buy the entire tie rod with both ends attached, over $100.00. Our semi-local shop did not have one in stock so we ordered 4 (2 for me and 2 for Lamont). Then we jacked up Lamont's RS and stole the tie rod off of his. Now that is a first! Using Lamont's ride for a parts bike for my ride made my day! :yes:
The swap was a piece of cake. The whole operation took about 30 minutes. Eye to Eye was exactly the same so my alignment issues should be resolved.
I doubt I can save that right front tire now. It's too far gone. I'll get 2 new fronts, put a new tie rod on (the one I stole from Lamont has over 50,000 miles on it) :yikes: and get an alignment.
wonder how long it will take you to get them from Lamont.you know UPS ships over there:yikes:
