Left mirror housing seems a bit loose - is someting missing?
Motogordo
I have a 2014 Spyder St-Ltd. My left mirror housing can be pulled out slightly from the frame. The right mirror doesn't pull out at all. Is there something missing under the frame or not ?
Thanks for any help I can get.
Motogordo
If I pull on the mirror housing it will pivot out about an inch from the spyder body and then go back when let go.
The ball has likely pulled out of the spring clip. Hard to snap it back in without taking the some of mirror apart. You may get away with just taking the deflector under the mirror off. Then a sharp thump on the top of the mirror should lock it back in.
