UtahPete
Well-known member
My Yuasa is dead even though it was on a charger/maintainer over the winter. I'd like to try the LithiumIron one recommended by Hypurone on a different thread....
But, that battery has very different dimensions than the OEM Yuasa. Can someone verify this is the correct replacement, or suggest another LiFePO battery that is a direct replacement. Thanks.
I am a HUGE fan of LiFePo batteries!... I yanked my OE unit after a couple of years when it started having inconsistent starting (ALWAYS on a Battery Tender) and replaced it with a Shorai LFX36 unit...The WEIGHT savings is HUGE! 4.55lbs (less if you don't get the 36 series like I did) vs the OE at 14lbs(IIRC)...
