Looking for 2026 RT Ltd or Sea to Sky equipment recommendations, brands/makes of phone mounts & cup/bottle holders, and a decent Half Cover?
bushrat
Looking for suggestions, preferred brands or makes of phone mount and cup or bottle holder for a 2026 Spyder RT Ltd/Sea to Sky model. Also, has anyone found a decent half-cover (not full cover; just overnight protection for windshield, seat and top case)?
Just traded in my 2017 F3L, which was a great ride, and starting over with a new '26 S2S, which needs accessories.
Thanks for any recommendations.
I use this from Amazon, but it's not a lightweight material. However, it's much lighter and more compact than the full size version that comes standard with the 2026 S2S (well, at least mine did - they did give you the full size cover, didn't they?)
XYZCTEM Can-Am Spyder RT Cover, Outdoor Waterproof Sun & Heat Protection Half Cover, Compatible with Can-Am Spyder RT 2020+ Limited, Black and Orange​
I use a Quad Lock Handlebar Mount PRO with a Quad Lock case for my iPhone. I put the mount next to the left handgrip.
I bought the following phone mount from BRP's Can Am accessories website:
Peak Design Phone Holder SKU # 219401317​
In order to attach the magnetic piece that glues to your phone, I instead I use a clear, smooth surface phone holder to glue it to as I don't want to mess up my actual phone. I got this part off of Amazon.
Clear for iPhone 15 Pro Max Case Crossbody Strap, Transparent Mobile Cover with Adjustable Neck Cord Rope PC Shockproof Lanyard Phone Case for iPhone 15 Pro Max Strap Women​
It says for women because it comes with a strap or actually a cord. I cut the cord down and made it into a loop which I hook over the handlebar in case the phone ever comes off the mount or the glued piece comes undone. So far neither has happened, or even looks like that is going to happen. I'm just paranoid. It's survived rain, 110F heat, and everything I can throw at either the mount, the glued phone attachment part, the case or the cord.
I mounted it on the right hand handlebar.
I have this phone holder:
And this mount:
Couldn't be more pleased with the looks, quality, and security of the system. I looked into the quad lock, but I didn't care for the fact that the case has a permanently attached mount which adds bulk during the other 95% of the time my phone is in my pocket instead of on the handlebar.
As far as the cup holder, I had purchased it from Kuryakyn when I had my Harley, then modified it to mount to a bicycle front derailleur clamp which perfectly fits the bar.
Many thanks; much appreciated.
And this mount:
I started off with the Top Cuff and added the RAM X-Grip on the long arm. I wear my phone in a holster so things like the quadlock won't work for me.
PXL_20260909_012930965.RAW-01.COVER-EDIT.jpg PXL_20260909_013002826.RAW-01.COVER-EDIT.jpg
jdg
