Bigmo
Good Morning Bigmo.
You’re almost there! All you need to do now is open Genius Maps from your phone (while NOT connected to Spyder). Using your phone, open Genius Maps, go to settings and make sure you set everything properly. I’ll try to figure out how to attach a pic to this thread but in the meantime, make sure the following:
Settings Tab:
Pro Guidance: North America
Voice: (choose any voice u like)
Vehicle Connectivity: NorthAmerica
Language: English/UK
You Can also go to Route Settings, click off what u want.
When done going through settings, click that Heart, go back to screen that shows map.
‘Close the app on your phone (but not a hard close)
connect phone to Spyder in Frunk.
‘Start her up, wait for everything to load. Now u should be able to use the steps In my first post on this subject.
‘Get your music playing, hold down joystick, scroll over to Genius Maps and launch.
I wrote a lot of words, but this process will take u about 5 min. I’ll try to take a pic of the screen and post here or PM you.
Good luck, pls let me know if this helps.
Jarred.
Jarred, thanks for the info. Well, I got it to work but not with the phone I wanted to. I have 2 phones, both Android. The Samsung Note 4 has V.6.0 but no cell data (disconnected) and my current phone with cell data LG Stylo 3 with V.7.0. I got all to work fine with the LG. The Samsung, which I don't use for calls, is the one I wanted to keep connected. I'm not sure if the version 6.0 vs 7.0 makes the difference. (I'm not sure if I can get the 7.0 version without a cell service). I have all the setting you list above on both phone. BTW, I extended the USB port in the Frunk to right behind the windscreen, so I can see the phone while doing all this. The phone, Samsung, doesn't shut off, just shows the outline of a phone with a cord attached. That alone tells me that it is connected properly. Anyway, I guess I'll use the LG since I'll have it in front of me. Wonder if a call comes in (not that I will try to answer) would the phone shows incoming call? I'll have to try that and have my wife call me while on BRP Connect. Anyway, thanks a lot for your help. I'll let you know about incoming calls.
