Looking for wire to tap into for remote wire for fuse block that is keyed
spyder-dude
I have found a few threads on this but couldn't find any specific to the RT except to use the marker lights on the front. The fuse block he is putting next to the hand warmers next to the battery.
I appreciate any comments on this as his bike is apart right now and can't seem to find one that will only power when keyed and wont cause issues with the can-am bus.
Thanks,
Shawn
RT or RS? On the RTS & LTD, you can use the light (LT GN/GY) for the rear heated grips to pull in your relay. For the remainder of the RT models and the RS, I'd suggest a running light (orange) wire. You should feed the fuse block itself from these circuits. The CANBus should not be affected.
