What is the maintenance schedule for the 2015 RT? I can't find it online anywhere. My dealer mentioned something about a 600 mile checkup.
Thanks!
Page 91 of the 2015 manual. Not the complete list but you get the idea. Dealer says bring it in at 600 miles. He will change the oil and filter(s), check a few things and you will pay his August house payment. Check the oil and other things yourself, take it in at 3,000 miles like the manual says and make his September house payment. Good luck.
At 3,000 miles
Check fault codes.
Replace engine oil and oil filter.
Check clutch fluid level (SM6 model only).
Check brake fluid level.
Check reverse mechanism operation.
Check engine coolant level.
Inspect throttle twist grip operation.
Check lighting system (brake light, hazard warning light, turn signal lights, position
lights, license plate light).
Check operation of control switches.
Inspect the drive belt condition and its tension. Adjust if required.
Check tightening torque of the front wheels lug nuts.
Check tightening torque of the rear wheel axle nut.
Check parking brake operation. Adjust as required.
Check tires wear. Align front wheels if required.
Check tires pressure. Adjust as required.
Visually check brake pads and discs condition.
Check passenger handholds looseness.
Check fo
