I use MS Streets & Trips for fuel stop planning, too. It has a fuel warning calculator in the route options. By checking each "Refuel Before Here" point, you can spot potential problem stretches, and fuel up early so you can get over that mountain pass or long stretch of deserted highway. Once I get on the road, I just hit the gas stops as needed, and find the stations with my GPS, but it eases my mind to have an idea ahead of time of where I am probably going to be needing gas. For trouble spots, I have even programmed the gas stop into my GPS.
Good morning,
I am planning a trip to Las Vegas this spring with my RT and I need to plan my stops based on a max of 150 miles between fill ups. How is the easiest way to do this? I think it can be done in Map quest and I have the Garmin software mapping but not a clue how to use it, lol.
Thanks for any help
Good morning,
Thanks for any help
Anyone ever use the odemeter??? And then carry an extra 1/2 or gal of fuel??
Good morning,
Thanks for any help
Thanks, I will try Google maps, never thought of that
Have a great one,
Randy
Has anyone used BaseCamp from Garmin. It is free as part of the 660 and does transfer to the Garmin.
