Metric back to Imperial
rockmantex
Went to start my F3 and it showed KM instead of miles. Look at manual and it said go to B.U.D.S. to change from metric to imperial. Couldn't figure out what BUDS was. Any suggestions on what to do?
If the controls are like the RT's, you change it using the "mode" button to get where you need to be.
Its a simple change using the mode button. Each time you hit the mode button the screen will advance to the next one. One of them will have the KM/MPH adjustment. Just use the up/down adjusters to put it in the setting you want.
Tried that but will give it another try. The mode button wasn't showing any choices. Thanks for replies.
Key must be on and screen booted up by pressing mode when requested...then additional inputs on the mode button will change screens.
If you look in your book, there is a small leaflet that has the steps to change from miles to kms. There is one in my wife's F3.
