I don't have a machine shop, so what you see is my prototype. I'll smooth the edges, round it down at the corners, and try to swirl buff them. Later, I hope to take them to a shop and have them fabricated.
Tools I used.
Cheap tabletop drill press ($35)
Portaband
Hand grinder
Calipers
Drill bits
Tap set
Materials
1" X 1" X 24" alunimum stock ($10.00 value)
Female Pegs - Drag Specialties PN DS253405
7/16" X 2" bolts (2)
1/4-20 hex head bolts (4)
Cut extension to 6 1/2"
Cut offset to 2 1/2"
Cut inset in extension to fit offset 1/8" deep
Cut offset to fit peg flanges
Drilled holes
Tapped for 7/16" and 1/4"-20 bolts
Stock peg
Left side
Right side(s)
Showing feet position without bags
Can now mount Cortech bags under hand grips, with panel protection strip tape
Tools I used.
Portaband
Hand grinder
Calipers
Drill bits
Tap set
Materials
Drilled holes
Stock peg
Left side
Right side(s)
