Anyone use one of these to lyft there Spyder?
https://www.harborfreight.com/1500-lb-capacity-atvmotorcycle-lift-60536.html
And they will chime in. I have the other model and it works well for me. Mine is from Sear's but the the same set up...
I have one. It is a little tight getting it under the bike so I routinely run the front wheels onto 2X10s before putting the lift in place. Works just fine.
Used regularly on my Spyder RT Limited, even made a wood platform to help raise the Spyder high enough (With jack stands) to change my sway bar. Has worked great!
