My DIY Ryker Rear rack
DickB
I don't like always carrying luggage when it is not needed. To reuse my Chase Harper saddlebags and Dowco Rally Pack tail bag on the Ryker, I made this rear rack. It bolts onto the Max Mount using existing holes; no alteration needed. It is made from 1/8" thick aluminum plate, painted with black texture paint. I think it looks better than the commercial alternatives, and my bags are custom fit to it. I can easily add or remove the bags in just a few minutes.
Excellent! I'm designing something similar for a Shad top case w/ universal base mount. You solved the attachment issues. Thanks!
What type of texture paint?
I used Rust-Oleum textured paint and Cowles Black Trim. Put the painted pieces on a cookie sheet, standing off from the sheet with some bolts, and bake at 325 for about an hour. I used M8 staimess steel fasteners with lock nuts, but the size is not critical, just drill holes in the rack and brackets to match.
Thanks for the info. I hope you have an oven in your shop. My wife would kill me if I tried anything like that in her kitchen.
Nice! Those bags look right on that bike!
Are you just allowing "gravity" to contain the saddle bags in place or do you support them at all to prevent them from moving. I like this! I am using the small LinQ bad for now but I may if I take longer trips on it do this, sure beats the cost of the BRP stuff.
The bags come with 4 frame loops that I'm using to secure the bags to the Harley supports. Quick disconnects if you want to remove the bags.
Nice work, looks good with the lines of the bike.
