Universal saddlebags on Ryker
bbells
I had some saddlebags laying around and decided to put them on my Ryker. I never removed them from my old bike, so I did a semi-permanent install. If traveling I always put stuff in a bag for easy carrying before putting in the saddlebags anyways. I bent a plate for a saddlebag support and put the saddlebag strap between it and the bottom of the max-mount. I didn't trust the aluminum threads in the 4 bolt holes on the bottom of the mount, so I drilled them through and used bolts with lock washers. Turned out better than I could have oped. Rather than pay $300 or $400 for limited storage, I paid $10 for parts and used an old set of $50 saddlebags. Easier to remove with the bolts vs the screws that the max-mount were made for. Not sure how to upload images. I will retry if this effort does not work.
pretty good design.... might be able to use some viking bags for a softail that I was looking at last night. The bags have no cut out for the shocks so more of a flat backplane.
Great Idea - very professional to drille the wholes through and use bolts/nuts .. I also didn`t trust the aluminum threads when I installed my topcase (some others do)
Would love to see more pictures. Looks great. Great idea. :2thumbs:
What did you make the plate out of? Does it have any support other than the bolts holding it down from the top?
