tofriendscreek
Need guidance on replacing the very bottom, front plastic piece on a 22 F3 Ltd. While traveling through SE Kansas recently, I found myself in a position where an approximately 4-5” rock was in the center of my lane. I couldn’t avoid it, but did slow prior to impact. I stopped at a Can Am dealer on the way home, where they graciously put it up and checked the underside. The only damage was to the piece mentioned above. I do not have a lift, so replacement will be done with the Spyder on ramps, wheels chocked, and the Parking Brake on. The new part is on order. I have not looked under the Spyder yet. In anticipation of changing this part, has anyone done this and what is involved?
In the picture, you’ll see the fractured piece I’m referring to being black, at the lowest center position. Thanks in advance for any guidance in replacing this part.
