viperryder
I have this problem with my 2011 RTS SE5 Spyder. In the past three weeks while ryding I get the following on my screen. First I get VSS and then DPS and finally Limp Mode. Had the Spyder in for first service and they found a loose wire on my HMBL. Fixed that and I thought all was well and good. Was going to take a nice ryde Saturday and while OUT in the middle nowhare the darn thing did the same thing, VSS, DPS and limp mode. Waited 1 1/2hours for service thought might as well try to go as far as possible. Well we made it all the way home, 29.2 miles no problem. Wrote email to seller of LED's and he suggested there maybe a loose wire or disconnect power to LED's. Did that and then went for a short ryde and no problems. Wednesday was taking the Spyder in for service and same thing happened again/ Took key out and waited for about ten minutes and started and made trip home again, about 24.6 miles. Called service people and they stated maybe a loose wire.
My question is why does this happen only in the twenty mile range? Why would a loose wire not cause problems all the time? Plus both times after waiting for a period of time was able to make trip home? Please anybody with suggestions, I am open to any and all help!!!!:banghead::banghead:
