Need some advice about a suitable cover sturdy enough to protect my Spyder if left outside for several months?
vito1943
Well-known member
Due to some garage issues, I may have to leave my 2021 RT outside for the winter months. I can still run an extension cord out of the garage for the Battery Tender, but the cover I now have for the Spyder is a lightweight vinyl type cover, which seemed fine for indoor storage. I'm hoping that some folks here can recommend to me a suitable cover that is sturdy enough to offer weather protection for several months outside here in the Midwest. I would have considered buying a storage shed, but local code prohibits me from setting up a shed in front or on the side of my house, and there is no way to get into my backyard with the Spyder. I'm not concerned with cost for the right cover. Thanks in advance for any suggestions.
Can you make a attached addition on the side of your garage big enough for say like your bike and yard gear?? A flapping cover will scuff the finish on your bike I believe!! Not to mention that it will make a great home for all the bad things that need a home.
What about one of those tent covers that you drive into and then pull down and secure. Can't remember the name and can't find a link right now. They're made out of heavy canvas and resemble a miniature quanset hut.
City code here prevents me from constructing a shed or such on the side of my garage. If I wanted to add a bricked extension to my garage I probably could get a permit for that, but the cost would be huge. I am looking into getting a storage unit, but so far have found that many of these units do not have electricity, and some that have electricity do not allow for something continuously plugged in like a Battery Tender. I have not asked the dealership where I bought the Spyder if they have a way to store the bike, but even if they did, it is located further from my home than I would like and of course the access that I would have, in case we have an unexpected warm day good for a ride, would be very limited. The "mini quonset hut" idea sounds interesting, and I would love to know where to find such a thing.
Put it the storage unit and take the battery home with you, then you could put the tender on and off as you want!
I could remove the battery, but would prefer to be able to get the bike out quickly for a ride on the unusually nice day in the winter when the roads are clear.
I looked into the Bike Barn but apparently they are no longer in business.
The storage unit might be the best for the bike, but all the ones near me are $100 a month or slightly more. That really bugs me.
The Speedways Shelter might turn out to be the best solution for me. $800 was a bit more than I thought I would need to spend. Speedway says to anchor the unit to the asphalt, but I worry that the city will deam it "permanent" and give me grief. Maybe it will just look like a covered small car and not be an issue with the city. Keeping it in my driveway will let me run an extension cord under the garage door and keep the bike on the Battery Tender.
Vito. You're getting to the point now that your concerns about the city can be answered with one phone call. Typically, zoning regs do not consider something permanent if it's not on a foundation, not easily moved, and meant to be temporary. Make the call, or just do it. What kind of "grief" are you worried about anyway. A permit? Get a permit, then. Speedway has a less expensive model of that structure without the floor. But, I would stick with the model with the UV protection at least.
How about this one on Amazon. Should be about the right size. It's $309 US.
Motorcycle Shelter Cover, Heavy Duty Storage Tent for Outdoor Use,136"*74"*75" 600D Waterproof Oxford Widen Shed Garage with TSA Code Lock​
You can install a Battery disconnect switch like this one. https://www.amazon.com/Nilight-Disc...witch,aps,359&sr=8-31&xpid=1yqdSCP78GVh9&th=1
Can you park a trailer in your yard with there promission?
