It opened for me.
It's a white Spyder pulling a trailer that swerved sharply to the left, then flipped and rolled.
The video does not capture the reason for the swerve, as the bike was already sideways when it appeared at the bottom of the video.
The video is from an Arkansas Department of Transportation camera on I-30.
The information about the video says it happened at mile marker 132.1.
The video description says: Two Injured After Trike Riders Flip & Are Crushed By Their Own Motorcycle
Lots of people stopped to help, and emergency personnel showed up at the 9:20 mark and were from a fire truck that then pulled into the picture blocking the traffic lanes.
Most of the people that had stopped headed back to their cars when the emergency personnel showed up.
Comments speculated that they might have blown a tire before the accident.
After going back over the first few frames of the vid reeeeaaaallly slow, I don't really think
that is the case - at least not either of the front tires, and even if the rear tire blew out catastrophically, surely it shouldn't (couldn't?? :dontknow: ) make the Spyder flip?! Then when the Spyder settles back upright at about 0:10, if you look closely, maybe even expand the image out, it's pretty apparent that both front wheels are still at least partially inflated, as you can see them keeping the rims off the asphalt! However, the left front wheel
IS at an acute angle, one not normally reached when the steering gear is still attached - maybe a failure there?? Or maybe that was damaged in the flip?? :dontknow:
As for it maybe being a tire blow-out on the trailer, check it out about 4:16 - 4:22, when the fella in the dark clothes rolls the trailer off the carriageway - it's pretty clear from that section of vid that both trailer wheels are still inflated - a trailer really won't move like that when pushed backwards with one or both tires flat, not even if the guy pushing it is the Hulk!
So I'd surmise that there was something else that happened back a little just before the sliding Spyder comes into frame. Maybe steering, maybe a wheel hit something?? Who knows what that was - I guess we won't know unless some more detail is released on what caused it!
But it does look pretty drastic for the couple concerned, I do hope they're OK. Anyone found anything more about them/their progress? :dontknow:
