A good quality car tire will almost certainly make the Spyder safer than continuing with the problematic and 'renowned for issues & failure' OEM Kendas, and running that car tire at 18 psi to cater for the lighter load of a Spyder, a tire capable of carrying a full sized car when inflated to 28-30 psi, it should also give you much better traction, steering, ride, handling, and more.
Running stronger/heavier car tires at 18 psi will likely feel 'different', possibly even 'spongy' initially; you may even feel as if the tire feels like it's flexing (or folding under??) too much during hard cornering, especially if you've been running them at anything much over 20 psi for a while before dropping them to a lower pressure more suitable to the lighter load. But that'll just be because you've become used to the lack of sidewall flex and compliance in the tire; when at a lower, 'more appropriate to the lighter load' pressure, the softer tires should be working to your advantage by keeping the whole face of the tire tread flat on the road surface. When they're over inflated, they don't do that, you'll scrub the edges of the tire tread during cornering, wear the centre of the tread more, and they'll be giving you an 'overly direct' steering feeling, and a lack of ride compliance, traction, etc, which is something you get used to and sorta 'expect' if you've been running them over-inflated for a while. You need to get over that feelingi, and remember that Radial tires are
MEANT to 'bag' a little more in the sidewalls;
and they
should feel softer and more compliant in their ride than the old cross plies that many of us became used to in the early days of our vehicular use/history.
But if you persist with running car tires at 18 psi for a while, the improved ride, traction, and handling this brings will very quickly overcome those odd feelings and the Spyder will likely astound you with how well it can actually corner and brake, as well as giving you great ride comfort and stability.
