New 2025 RTL with heavier steering than previous 2019 - anyone else noticed this? What would help?
heliboy
Just bought a 2025 RTL for my wife. We had a 2019 F3 3 years ago and lost it in a wild fire. The steering is harder than what we remembered. Has anyone else noticed this? Could changing the front tires help?
The newer model Spyders (2020+) have noticeably less steering assistance than the 2019 & earlier Spyders while your Spyder is stopped but running; more steering assistance once you actually start moving; then as it has always done, the steering assistance tapers off as you go faster and need less assistance to keep things smooooth! ;)
So unless you have little or no steering assistance between about 5 mph & 35 mph, then it's probably got the normal amount of steering assistance for that generation of Spyder; altho if you are running your front tire pressures significantly too low then that could make your steering feel a lot heavier than is ideal. By too low, I'd say anything 2psi or lower than the placard recommendation for the OEM Kendas or any of their derivatives/clones; or anything much lower than about 16 psi for a 'real' car tire with stiffer/higher load carrying capable sidewalls.
The OEM Kendas &/or any of their derivatives/clones really NEED that placard recommended pressure to carry the (relatively lightweight) load of the Spyder, so varying their pressure by anything more than +/- 2 psi is not really a great idea; but the significantly strong/higher load carrying capabilities of any tires (NOT Kendas/clones) that are safe to operate under a car means they need no more than about 18 psi to carry the load of a Spyder! However, you also need to be aware that going too much lower than about 2 psi lower in any real car tire (ie, about 16 psi) means that they'll be under-inflated enough to raise concerns that you might pop the tire bead off the rim during cornering, and that can be deadly! :oops:
Thanks for the fast response, I was wondering if a car tire might make it easier for her to steer the bike. I want her to be safe, that is my priority.
A good quality car tire will almost certainly make the Spyder safer than continuing with the problematic and 'renowned for issues & failure' OEM Kendas, and running that car tire at 18 psi to cater for the lighter load of a Spyder, a tire capable of carrying a full sized car when inflated to 28-30 psi, it should also give you much better traction, steering, ride, handling, and more.
Running stronger/heavier car tires at 18 psi will likely feel 'different', possibly even 'spongy' initially; you may even feel as if the tire feels like it's flexing (or folding under??) too much during hard cornering, especially if you've been running them at anything much over 20 psi for a while before dropping them to a lower pressure more suitable to the lighter load. But that'll just be because you've become used to the lack of sidewall flex and compliance in the tire; when at a lower, 'more appropriate to the lighter load' pressure, the softer tires should be working to your advantage by keeping the whole face of the tire tread flat on the road surface. When they're over inflated, they don't do that, you'll scrub the edges of the tire tread during cornering, wear the centre of the tread more, and they'll be giving you an 'overly direct' steering feeling, and a lack of ride compliance, traction, etc, which is something you get used to and sorta 'expect' if you've been running them over-inflated for a while. You need to get over that feelingi, and remember that Radial tires are MEANT to 'bag' a little more in the sidewalls; and they should feel softer and more compliant in their ride than the old cross plies that many of us became used to in the early days of our vehicular use/history.
But if you persist with running car tires at 18 psi for a while, the improved ride, traction, and handling this brings will very quickly overcome those odd feelings and the Spyder will likely astound you with how well it can actually corner and brake, as well as giving you great ride comfort and stability. (y)
A popular alternative to Crapendas is the Vredestein Quatrac 165/60R15 that is listed in stock at Tire Rack, just confirmed stock status on phone. I have 5,000 on mine and they are the best front tire I've had on my Spyder
What year Spyder do you have? Thanks for the info.
From 2013 on, when all Spyders got the (bigger & better) Brembo Brakes, it really doesn't matter what year Spyder you have when it comes to tire sizes - they're all the same, OEM fronts = 165/55R15 Kendas; OEM rear = 225/50R15 Kendas; After market tires, fronts = 155 to 175 wide, 50 to 65 profile, 15" rim dia; a/mkt rears = 205 to 225 wide, 50 to 65 profile, 15" rim dia; altho if you want to start playing with a/mkt rims &/or custom fenders etc, there are others that can fit, altho the bigger variations may cause some issues, ie, changing the rim offset too much can cause some rubbing issues despite still running the above mentioned tire sizes, as at least one member has discovered. As for the pre-2013 Spyders, they had 14" rims up front & BRP brakes rather than the bigger & better Brembos. ;)
However, if you search on tires here, there's a vast amount of info to be had if you search and spend some time reading; but as most who've explored the limits of their Spyder's performance and handling characteristics have discovered, just about any reasonable quality a/mkt tire that fits (within those size parameters above) will provide significantly better performance in all respects to the OEM Kendas & their derivatives/clones as well as increased longevity too, just so long as you run the (stronger/higher load capable/better quality control) a/mkt tires at an appropriate pressure (lower) for the lighter load of a Spyder vs the weight of a car. That said, I've yet to find anyone who is really massive enough &/or loads their Spyder heavily enough to truly warrant running pressures higher than 18 psi in their a/mkt tires, altho occasionally, some have played with going as high as 20 psi for extended high speed, heavily loaded, &/or high temperature runs, conditions where that higher pressure might not be unwarranted. Onky when it comes to the correct pressure for OEM Kendas & their clones/derivatives, almost all who've persisted with them have found that because they are so lightly constructed, they really NEED to be within +/- 2 psi of their tire placard recommended pressures. ;)
Still, when it comes to tires (& oils!) it really does pay to do some searching and reading - there haven't been any massive changes and there's really not too much about any of those subjects that hasn't been asked, discussed, and answered extensively in the years since Spyders first hit the streets/the SpyderLovers Forum went live. (y)
Enjoy! 😊
See my signature, a 2014 RT-S. If you put your year and model Spyder in your signature (see the linked Sticky below) viewers will see it and won't have to ask you what yours is if you ask a year and model specific question, nor will you have to type it each time you ask a question.
See page #7 post #129 for details on how to do this on the new/current Forum platform.
