New Accessory converts wired CarPlay to wireless CarPlay
Snowbelt Spyder
Well-known member
To be clear, I have NOT tested this on a Spyder. Just an FYI if there are any takers out there.
PS. NOT an add-on CarPlay unit. Just eliminates the USB cable for the existing CarPlay function.
There's been a few other posts about wireless adapters for Apple CarPlay and Android Auto.
Since I'm an Apple iPhone user and plug my phone into the USB port in the glove box I have no use for something like that.
Thank you. This accessory plugs into the USB port of the Spyder and eliminates the need for that USB cable by establishing a WiFi link to your phone in place of the cable. I thought some would be interested in eliminating the USB cable if it worked. I searched but wasn’t aware of other posts on the subject.
There's this:
No Racoon. This isn’t that add on unit at all. It’s only just 40 bucks. All this unit does is eliminate the need to use a physical cable between your phone and the Spyder, like the one you currently use. A person still uses the built in CarPlay on the Spyder. It’s just a convenience thing if a person wants to stop needing to connect the USB cable. I’d recommend that you actually go to the link I supplied and check it out.
