Raprider
Hi...name is Raprider (Rap or Rich will do)...I'm in NJ...riding 25 years or so, currently riding a 96 Virago 750 but lately have concluded I'm not getting appreciably taller (5-1), younger (53), or stronger (only better looking!), so I have been considering the Spyder for some time now.
Most riding is 75-100 mile mostly country road days with dearest spouse on pillion.
Would like to be able to do longer days/trips (with necessary highway jaunts) that just aren't comfortable on the v-twin.
I've demo'd both RT and ST and leaning toward the ST, mainly for the fact that I feel like I'm "inside" on the RT...leaning gently used not new, and thinking to pull the trig before the winter sets in, considering prices may be softer now than in spring.
I seem to have found a 2013 ST Limited with about 7,500 miles on it, located at a dealer about 200 miles away, and wanted to run a few questions past you guys before contacting the dealer.
Maintenance - will the dealer be able to determine via VIN if the STL has had the necessary service/maintenance even if they did not do the service themselves, or do I need the VIN and to contact a local CanAm dealer?
Having read thru several pages here, I'm thinking I need to know about:
Other questions I would have, based on the photos I am looking at:
Okay...that's enough for this post!
As you can see, I'm trying to figure out what I need to consider before considering a 200-mile trip!
Thanks for listening and looking forward to all your valuable input.
Rap
- 600 mile and 4600 mile oil changes
- heat dissipation shields...can i tell just from pics?
- brake reservoir heat shield
- tire/brake status
- brake code install (I read one thread here about this for someone "riding the brake")
- is any kind of warranty available? probably not...maybe just a 7-day or 30-day???
- this ST currently has an Ultimate seat w/driver and rider backrests...are these adjustable for depth and/or removable (particularly driver) if I don't like it?
- how can I tell which Ultimate seat it is (short, reduced or mid)?
- this ST currently had driver footpegs, not footboards...I thought boards were standard?
- front fender lighting appears to be mod'd...almost look like spot lights and the 'over top" strip and lighting is different than others I have seen...aftermarket???
- Heated Grips...in photos, I only see Parking brake switch and then blanks...and it looks like the far right blank was replaced with a Batt Tender USB connection...shouldn't one of these be a switch for heated grips???
- Cruise control? Looks to have a throttle-rocker installed over the foam grips...though one pic of the dash panel lcd shows "CRUISE OFF" in the lower left corner
Rap
