OEM rear tire soecs
Coyne Spyder
Have the specs changed on the standard OEM rear tire? I read in several posts concerns about wear in the center of the tire due to ballooning at highway speeds and reason given that it is a tire with a 2 ply tread. I had similar experience with the center being warn and edges still good with 7500 miles. I had a new tire installed at Pitbull in May and it is 3 ply tread (1 polyester, 2 steel) and 1 ply sidewall (1 ply polyester). It is standard OEM tire because that is all they would install.
