Oil change - which way to undo the drain plugs?
Micnice10
Sorry for the dumb question, but when removing magnetic and secondary drain plugs is it opposite twisting? Righty to loosen?? Thank you much!
I ALWAYS set my ratchet to either tighten or loosen BEFORE I use it ..... this prevents mis-takes when you are using it up-side down ..... good luck .... Mike :thumbup:
I always check the rotation of the ratchet before applying it to ANY FASTENER, even visible ones. Just because it faces downward doesn't change the direction of the threads.
Uhhh, if you don’t know the direction to loosen a drain plug, maybe you should not do your own maintenance. Just saying for your own good.
All I’m saying is if you put your ratchet to the LEFT you will tighten your drain plug!
Now how do I adjust my clutch.....:) Have a great day!
Looking at the end of your drain plugs, anti-clockwise to slacken, clockwise to tighten.
If this thread is not a troll, I suspect the OP's direction is based upon reaching under the Ryker, rather than on ramps looking up at the drain plugs.
Looking at the plugs, they are standard right hand threads...so, CCW to loosen...same as spark plugs.
If someone tries to loosen the in oppsite direction, stripped threads or cracked case can result.
Use a ratchet handle and check its rotation before applying it to every fastener. You can't go wrong unless you're dealing with a left hand thread and there are very few of those, thank goodness.
Did oil change today, DEFINITELY RIGHTY TO LOOSEN and LEFTY TO TIGHTEN!! Have a great weekend!
Wrong, wrong, wrong - both those plugs are NORMAL threads ..... right to tighten - left to loosen ...... Those plugs are up-side down, but that won't change the direction of the Threads on the plug...... this is why ( as I stated above ) I always set my Ratchet BEFORE I use it ..... Mike :thumbup:
I don't understand how anybody could get confused just because the plugs are upside down. Putting in bolts overhead, you flip your hand over palm up. Don't matter if the bolts are above or below you. To put in bolts going down, have your palm down. They all turn the same way, unless they are reverse threaded. I guess I just been turning wrenches so long I don't think about it any more.
I think every mechanic that I have ever worked with subconsciously checks their ratchets direction before using it, even tho muscle memory will instantly tell them it's wrong
I worked as a press line mechanic for 30 years, and I still occasionally have to stop and think which way an upside down bolt turns.
And I always check the ratchet rotation before use.
I don't understand either, but when I was training guys to be repairmen, every one of them would start to turn an upside down fastener the wrong way. I say, stop, what are you doing? They'd answer, I'm loosening it and were surprised when I told them they weren't. They'd even try to argue the point. That's only one reason of many I don't trust guys with tools and my vehicles.
