Cobranut
Well-known member
I've noticed on my new-to-me 2015 F3-S, that when I initially turn on the key, the gauges sweep and all warning lights illuminate for a second or so.
Before cranking the engine, I'd expect the oil pressure light to be on until oil pressure comes up.
However, my O/P light stays off even before cranking. It also doesn't come on when I kill the engine with the kill switch.
Can someone with a 2015 F3 verify if this is correct? I plan to install a gauge, but I don't want to be running around without any oil pressure monitoring until then.
If you can post a video of your startup, that'd be even better.
Thanks,
David
Thanks,
David
