Our 6x12 enclosed trailer set up for our Can Am Spyder S2S
Well I will be happy to throw you some ideas when you get that far, been RV’ing for 35 years and owned everything from 5th wheel to diesel pusher. When we trade in or get another one, it will have rear twins, hard for a 6ft guy to sleep on the bed, and already almost killed myself on the upper berth. LOL
@NutinElse2do - I appreciate the offer, and I will take you up on it! So far, in my limited search, the must have is a queen or bigger bed, and kitchen/bath access with any slides (if we end up with them) not extended. This coming from a couple that has not even been to a show to compare models - so everything could change. We are also thinking enclosed trailer for the bike, but again, a few years out before any commitments are made.
@DOR55, it is a Primo UT6x12. I bought a tri-fold ramp and drilled out the hinge rivets. I was using an insert with a few inches of drop, then recently I installed the F150 reverse leveling shackles which lower the rear of the truck, so got another insert with less drop.
I made up pins out of 1/4x20 SS bolts that drop into holes in the OEM tailgate. I also drilled holes to put down two ramps for low golf carts.
For long trips it gets belts and suspenders! Third picture is the rear tiedown plate with Nylon cutting board milled to give a wider area for the rear tire to sit on. I had the chock type Erickson plates in front and behind the front tires, and the Spyder had a hard time backing out of them, so I switched to short plates behind the tires. Fourth picture is under the trailer showing how things are bolted down to the deck.
View attachment 254164 - View attachment 254165 - View attachment 254168 - View attachment 254169
Snoking,
Thanks for the great info!
Our 6x12 enclosed trailer setup and road trip to BajaRon’s is finally dialed in.
After completely overthinking every single step of this process, we’re now at a point where everything is set up and, most importantly, we’re both comfortable with it.
Here’s where we landed:
  • Tongue weight at 425 lbs, 13% of loaded trailer @ 3300 lbs
  • Trailer weight under the RV’s limits
  • Etrack Wheel chocks in the front to prevent the wheels from turning (Clearance is tight)
  • Front tie-downs to the shock eyelets (Thanks Baja Ron)
  • Side tie-downs to the passenger footrest hole eyelets
  • Rear tie-down to the floor
Had to move the cables that help the door go up out by 1” to give us the clearance needed.
We also installed a wireless camera inside the trailer so that we can keep an eye on everything while traveling. We are guessing at least 7-10k miles.
We’ll be heading East from Arizona in our little RV, pulling the 6x12 trailer across to the East Coast, with a stop at BajaRon’s and plenty of rides along the way.
Looking forward to the Tail of the Dragon!
For anyone who is looking to make a 6x12 trailer work, here are some pictures.
View attachment 254079 - View attachment 254080 - View attachment 254081 - View attachment 254082
Nice job on prepping the trailer for hauling the Spyder. I am in the middle of getting a utility trailer ready for towing our RT and we are also installing E-track chocks. With so many vendors offering those style chocks, can you please let me know where you purchased yours? I noticed that your tires fit nicely in the chocks you used.
Thanks . . . Don
Thanks for the compliment, we used the ETrack wheel chocks and actually bought them from tractor supply.
We left Baja Ron’s a few weeks ago with new shocks and actually upgraded the tires to the Vredestein and they fit perfectly as well.
Let me know if you have any questions….
Snoking,
Am about ready to pull the trigger on a similar setup. Am curious as to how the Spyder-loaded trailer setup affects gas mileage on your pickup at Interstate speeds (ie: with and without trailer).
Thanks in advance!
DOR55
Snoking,
Thanks in advance!
DOR55
I tow it with a 2021 F-150 SC 4x4 with 2.7L Ecoboost. Truck get 22-24 MPH on freeway driving. Between Arizona and Washington I get around 16-18 towing with the Spyder on the trailer. SxS on the trailer was 15-16. I stay at a max 65 when towing.
