Pairing up Zumo 660 with XBI2 Headset
Call Garmin and see if it's on their tested and approved list. I had a problem with another model last year and they said they didn't support it.
pairing
on the helmet you need to push the 2 buttons, mode and power quick, no more than 3 sec.
on the Zumo you need to be in bluetooth mode, goto tools/settings>bluetooth
under phone touch add look for XBi2-H
you have to enter 1234 when it asks for the code
I found that i held the buttons on the helmet too longer and it did not sync
hope this helps
it does work good when you get it
geo
Thanks, I will try it again following your instructions. I was told that the Zumo's are the only bluetooth models in Garmins line up that will pair with the XBI2.
Regards,
Randy
