accaptain777
This may have been addressed previously, but I'm not running across a thread for it. I had hip replacement and haven't ridden my 2018 F3-S in about a month and a half. The first time I started it (thinking I'd let the battery charge) the parking brake released and I was able to roll it forward out of my garage. I then reapplied the parking brake, which worked. However, when I went to release it to roll it back into my garage, it wouldn't release. I tried multiple things, and I ended up having to back it up in gear with the parking brake on. I wasn't recovered enough to mess with it, but I did start the Spyder off and on during recovery that month, each time trying the brake switch, which did nothing. Yesterday, I removed the parking brake cover and released the spring and cable, allowing it to roll. I tried the switch with no tension, but again ,no movement of the cable. I took the side plastics off, and I can now see the parking brake motor. When I hit the switch, I hear a faint noise coming from it, but of course, no movement of the cable. If my battery is down in voltage, even with me starting it occasionally, could this cause the parking brake failure? Anyone experienced this situation?
