Rob Rodriguez
Picked up my Rally today and rode it about 100 miles.  I noticed when "coasting" (no throttle and no brake) for a longer distance down steep hills and on flat ground to a stop sign the bike physically clunks.  Clunks meaning, it will surge in speed like its freewheeling, then slow quick like the transmission catches, then surge like its freewheeling, or to put it another way.  If you have a manual transmission vehicle and don't give it enough gas and pop the clutch the vehicle will jerk along.  Now this only happened a couple of times.  Other than that the bike was completely fine.
When the RPM on the engine drops to below CVT engagement the belt becomes lose in the clutches and this lets the bike "freewheel" so to speak. What could be happening is the belt is lose in the clutch and then tightens for whatever reason and then loosens again and this is causing this jerking action. Might be why its only happened a couple of times and on longer coasting distances? This can/does happen on a snowmobile sometimes when coasting down a long steep hill. I'm riding tomorrow and I'm going to try keeping the RPM higher (right at engagement) until I stop at the sign on the same long hill it did it on today. See if it does it again.
Just to clarify this hasn't happened during from a stop or while rolling acceleration and it doesn't happen if I let off the throttle slow down a bit and then give it more throttle and accelerate. It's just when I do a longish coast to a stop (stopping with the brake at some point not letting it coast to a stop)
My question is.......Has anyone else had this happen to them? I have the feeling there is nothing wrong and this is just the way the bike is but wondering if others have experienced this?
