Recluze
I have been blessed with 33,000 trouble free miles. Well that party is over.
So I changed the oil and changed the plugs. To be fair I went from an "8" to a "9" on the heat range of the plugs at the dealers recomendation. I have the heat sink paste on the plugs. Plugs are torque to spec.
Replaced a spark plug wire that I broke screwing around with the plugs.
Started it up and oh baby it ran like C%$p. Took it for a ride and the engine stopped running at one point. No fault codes. No limping.
Brought it home and pulled the plugs. The forward cylinder looked like it was running rich-kinda black.
Disconnected the battery and let everything reset. Started it and it really ran bad shutting off several times. Checked for fault codes but there are none.
Obviously I did something in changing out the plugs but I am at a lost as to what. I pinched off the Evaporative hose and that did not improve things. I am stock except for a ground wire from the coil to ground.
Wow! I miss the Spyder I fell in love with. Any ideas?
