GRHorst
My GPS on my 2021 F3L plugged into the glove box connector was a problem. Using that connector the F3 tries to connect like it was a phone and caused errors on the GPS. My GPS then failed, and I don't know whether this Spyder connection played a role. But I was suspect. So I wanted a separate power source for the GPS.
I purchased the BlueFire 5V/2.1A Dual USB Charger and cigarette lighter type socket for the Motorcycle Handlebar. Then I wasn't sure which way I wanted this, switched or not. I ended up with this unit always live since it has it's own switch (red switch on the top) and is fused. I like having the voltage display to keep an eye on voltage which usually shows around 12.5 when not running and 14.5 with motor running.
I'm sure there are valid reasons to connect via the accessory connection provided in the system. But this way I can punch in a route before starting the Spyder.
The other issue seems to be that my GPS wants more power to charge the battery than the 2.1A USB. It will charge the GPS if using the 12v power adapter. But using the USB I get a warning on the GPS that there is not enough power to charge the battery.
