Procedure to Adjust Belt
ulflyer
I assume if one wanted to adjust the belt, the axle nut needs to be loosened by holding the large one on the left and loosening the smaller one on the right. Is this correct?
I understand the technique for adjusting the belt itself.
both take the same size wrench 36mm or 1@7/16 at least thats what my 2010 rts takes.the trailer hitch has to be removed first
