Went to inspect the rear wheel bearings and replace the seals in accordance with the maintenance schedule. I was surprised by two things. First was the accumulation of brake dust in the rear hub. The second was the fact the bearing on the hub side is floating, not securely positioned in the hub. See pictures below. Certainly not what I would expect having never seen this in 30 years of working on vehicles. It looks like the hub spacer was scored on the side as well indicating a bit wobble at some point.
Is this normal or is the rear wheel hub bad? Nothing in the factory manual or how-to videos showed this type of tolerance for the bearing.
