getting ready to change rear brakes I think I know the procedure but would like to verify before I start. I assume you need key on and release parking brake,then remove nut holding plastic assembly and spring. then remove assembly, turn shaft to loosen parking bake,after that just normal disc brake job,next assumption,i should gently pump up the brakes beforereinstalling park brake. to adjust park brake I turn shaft til brakes just touch then install park assembly PLEASE IF THIS IS NOT CORRECT LET ME KNOW BEFORE I GET STARTED . all help and input is greatly appreciated mike. almost forgot, I had another post about brake wear found read brake to be sticking sometimes, is there anything I should look for or do maintenance wise to correct or prevent this
