Rear Brake Pad Replacement
Depends....
I would..cables strech and if you adjusted it as the pads wore you should most aftermarket pads are thicker so you should and some models you have to... piston/s will not return if you don't back the park brake off...
ADJUST PARKING BRAKE
Is there any need to adjust the park brake cable after installing new rear brake pads?
Gunner
...I haven't heard of anyone needing to do this if it was working OK prior to the Pad change ..... I recently did my pads and didn't do anything other than screw in the piston to make room for the thicker pads .... my Park brake works just as it did before ...... Mike :thumbup:
:agree:
I've done a few brake jobs on RT's and I've yet to have the need to adjust the park brake cable.
