Pandy
Got the rear pads replaced with little trouble and gained a lot more pedal as well. Next pads will be 10 k miles sooner. Meanwhile, the parking brake works as well as it ever did, holds Pyder on hills, Pyder will not move when brake is set and throttle applied. My quandry is this; the brake pedal doesen't "kick me in the foot" when I apply the parking brake. My Pyder has done this since day one, and now it won't. So, what do you think? Too much cable tension? Not enough? The pulley moves "slightly clockwise" as described in the manual. Or, the "kick in the foot" was incorrect from day one? Oh, and no more squeal and groan from aft when backing. Just the squeak from the fronts until warm. Yes, supposed to be new generation pads on the front. So, gearheads, what do you think?
Patrick
Patrick
