Hello, does anyone know where I could get some rear spring stiffeners for a 2015 rt? Would like to easy the work on the bag when riding two up.
Thanks
you cant stiffen a spring...sorry (docs coil eliminators work tho)
the air bag restores ride height when weight added
you need an aftermarket shock by the sounds
russ
What's wrong with letting the air bag do its job?
If I had <my> way, the suspension would be ALL air, no coil springs.
You would ALWAYS have the proper spring rate for the load, and could maintain a constant ride height.
I realize that would be a perfect scenario, but my experience is with over-the-road semi trucks and also with S&W suspension on an early KZ1300 motorcycle 40 years ago.
Wellll, technically you were right with the first bolded bit, Russ! :thumbup: But not with the second bolded & underlined bit!
Even Doc's coil eliminators aren't really 'stiffening the spring', they're actually only shortening the free coil length while maintaining & possibly slightly increasing the static spring height - so the bit of 'un-bound coil' that's left working is still the same rate as it was before, ie. no stiffer or weaker; but because the 'eliminators' are stopping a couple (or more) of coils from doing anything but maintaining height just like a couple of fat washers would - or if you like, they work in much the same way a 'too light' coil can still 'sorta hold the suspension up' even tho it's bound & fully collapsed.... only in this particular case the spring 'stiffness' hasn't changed, it's just got less height to compress cos a few coils are already bound..... and the only relief you'll be giving the air-bag zz, is really when the spring 'bottoms out' early & applies all of that compression force jarringly thru the frame! Which is definitely NOT a good idea!! :lecturef_smilie:
So zz, if you want to 'ease the load on the air bag when riding two up', you really need an a/mkt shock & heavier coil combo - or that 'full air bag' suspension Steve W mentioned, preferably 'full a/mkt' too! :thumbup:
hi pete
i still maintain that RR spring coil eliminators work......ie they dont stiffen the spring but they do stiffen the ride
but having read a recent post from Baja ron re raising/lowering the front suspension height and consequently stiffening/softening the ride,which absolutely floored me, i completely withdraw from this subject as i now realise i dont know diddly squat about spring reactions and ride height and adjustable suspension per se
russ
What you need is a half of set of Doc Humpries front spring spacers...He sold front spring stiffeners in sets of 4...And he also had 1/2 sets that worked on the rear spring...Doc has disappeared, but there may be some SL members that have some laying around,,,They are easy to install...I have them on the rear only of my 2014 RTS for several years...I can ride 2 up with no air in the air bag if needed...larryd
These are aviaalave at auto parts stores and Summit racing. I'm going to look into them.
Larryd----- Was the install difficult????
Lew L
Mine were not difficult at all, Maybe 15 minutes...Just position them between the coils and turn 1/4 turn with a socket,extension & ratchet...But I do have a automotive lift in my garage with adapters for the Spyder...
With all the air compressor and component failures I needed to have something that I can continue to ride 2 up with...I got caught one time riding 2 up with an air ride failure...Impossible for us to ride 2 up when the failure occurred...Rear tire rubs hard on the inside of the rear top fender...Yes I also carry a small portable air compressor, but when the air leaks out as fast as you put it in, its no help...larryd
Thanks Larry:thumbup:
I'll use a HF jack and remove the long thin panel exposing the spring. I want to use the rubber ones though.
Lew L
Well---- I gave up.Could not get the shock stiffeners in between the coils even after cutting them down some, lubing them, striking them--- no go. Then I tried to remove the rear shock--- a ture pain on the top bolt- gave in on it also. I may try next week.
