eddieshep999
I intend to change out my rear suspension unit on my Spyder RT - S 2010 SES Model from the stock one to an Elka one
Whilst doing this I want to also change out the original Bolts for Stainless Steel ones
Having looked on the BRP Parts section for Spyder RT - S 2010 (also for the Spyder RT Limited etc 2011/12 models)
it Shows and lists the bottom bolt as M10 X 140 and although it shows and list the top bolt no size is quoted
I assume it is an M10 Size but what length is it ?
I am sure others will have replaced the Rear suspension on the Spyder RT - Can anyone give me the answer ref the bolt size
I will also change out the front suspension again from stock to Elkas and I understand both sides top and botton use
M10 X 60 Can someone confirm this also as again I want to use Stainless Steel ones
Thanks
Eddie Sheppard
Reading UK
Thanks
Eddie Sheppard
Reading UK
