IGETAROUND
Well-known member
I have a 2018 F3-T that has developed a clunking sound from the rear axle. The closest sound it is similar to a worn CV joint on a front wheel drive vehicle. I suspected that the rear sprocket rubber cushions were worn so I replaced these, noise still persists. The metal spacer that is between the wheel bearings is easily moved side to side when the axle bolt is not in place. The wheel bearings are good, no looseness or grinding. If the wheel bearings are properly seated can the spacer tube easily move back and forth and side to side? If the bearings have moved from fully seated, how does this happen on a properly torqued rear axle? I would appreciate your thoughts and ideas on how to make this noise stop. The noise has just started within the last 500 miles. Bike has 88K miles currently.
Al in Kazoo
Al in Kazoo
