Recommend any Rear shock replacements other than the $$$ Elka's??
Dmetcalf
I am thinking about replacing the rear air bag/shock with a standard shock absorber and would love to replace it with an Elka, but $875 for it is a bit much in my book (for a single shock)! Has anyone found a good replacement shock other than the Elka shock?? Thanks.
I thought that kind of money was too much as well. Until we started to build our own shock series. It boils down to the hard fact that a good shock is going to cost you. Just no way around it. This is why most OEM shocks are just adequate, at best. Many aren't even that. Manufacturers shave a lot off the price and it gets you out the door.
The harsh reality is, you live with what you have, or bite the bullet and get what you need. I'm with you, I wish it were different too. But wishing has never gotten me very far.
Trust me, if you bite the bullet, you will not be disappointed in any way! I want to believe BRP has maybe seen the light after putting some great rebuildable shocks on their Canyon, and Ryker, maybe they will start doing it to the rest of the line up! The bag and shock combo are great when it's new, but it will fall on its face after a few years; the compressor or bag will fail, the shock starts to lose its guts after a while, and you don't have as nice a ride as you used to! Put a nice aftermarket shock on and you can dial it in to your style of riding, and when it starts to fade, then you can have it freshened up and have a new ride all over again for a lot less money! You will have something you can fix and adjust to suit the way you want it, instead of something you just have to get used to because that's all you've got, no other option! Good luck!!
I’ve got 35K miles it my 16 RTL and so far 🤞the rear suspension is still working fine; but I too am starting to get wary about how much longer it will keep working. I love the difference the front Elka shocks made in the handling, and I’m quite sure the rear Elka would have the same result for me. The high price has me on hold though!! Why so much for a single shock is my question??
Wilbers are slightly cheaper at $839.58 from EPM Performance, but you'll wait 4-6 weeks as they're built completely to your specs in Germany. They went up about $50 due to tariffs. That said, EPM offers a 10% discount for military and first responders.
I have WIlbers up front on my 2022 RTL and absolutely think it was worth time and money! Since my wife put a limit on how much I can spend, I am going to switch the back over the winter when I do a lot less riding.
Good to know. Thanks. Any discounts are worth a look, especially if the quality is there!
I love my Wilbers. I was hesitant at first due to the cost, but after installing them, along with a BajaRon sway bar and the Quatrac tires, provide an amazing ride. It's a little bit more of a hard ride, but the control is amazing. No drifting in corners and no bottoming out with a pillion on board.
Dang, that does look like a high quality product!! Thanks.
Another reason I choose those over the Elkas, is that with the Elkas, they have external reservoirs on them, which in my mind, if they are not needed then they are just something else in the chain that can fail. The Wilbers are a high quality, precision made, item that does not require external reservoirs. They are tuned to your specs, as they will ask you some questions when you order them, and they will be built specifically for you. All you have to do is bolt them on and you are ready to go.
I have the external hydraulic preload adjuster on mine, you can see the red handle right underneath the seat on my sig pic.
I am quite sure the Elkas are of high quality and many people swear by them, but I will stick to my philosophy of sometimes less is better when it comes to Murphy's Law.
No problem. You're paying the bill so you get to apply whatever philosophy you like.
Elka's for the RT don't have an external resi or a compression clicker or I would have gotten those options. The only failure points added are the hose and a couple more o-rings? They have been around a long time and the product speaks for itself. My biggest issue with Elka was a slight irritation with the language barrier and no direct access to a tech.
Remote preload adjusters are cool, but I just got the right spring rate installed and let the air bag adjust for changing loads as needed?
I see Ron is partnered up with JRI which is also a class act, I just couldn't get behind their low supplied spring rates and no rear shock option yet?
