Rear brake caliper piston will not fully retract any ideas? Or just rebuild &/or replace?
SubjectX
Greetings,
long time lurking, but I guess my time has now come and I need your help, fellow peeps.
On a RS, 2010, with 15,000 km, the rear brakes are working fine-ish, but the disc is glazed and there is a constant sound of grinding when turning the rear wheel.
So I decided to replace the pads and sand down the disc a bit to remove the glazing.
All is fine, but when it came to retracting the piston back into the flush position, since I couldn't install the caliper with new, thicker pads (but only for like 0.7mm thicker), it wont budge for the last 2mm. It compresses on the handle and on the parking brake, but always 2mm remains outside of the caliper.
The pads, still original, are not worn at all, maybe 0.7mm thinner than the new pads. Their surface has a similar roughness to the new ones.
I'm from Europe.
I guess the caliper with piston needs to be rebuilt, at least two separate AIs suggested that before getting a whole replacement. In Slovenia, I can no longer find any service places, that will work with this old model, thus I'm stuck in DIY mode.
I can take the caliper apart, but I would need to source spare parts in advance. Can anybody comment on my plan and/or point me to the correct rear caliper seal kit?
Also, while we are here, which engine oil, apart from that really expensive OEM labeled one, should be put into my Spyder?
Apologies if you have already done all of this. Most common reason for this is that the internal parking brake mechanism still needs to be retracted further. You say it compresses on the handle and the parking brake, but not sure what you meant by that. In 2010, depending on when your bike was built, it had either a lever and spring or a cable pulley wheel that operates the parking brake. In either case, these components need to be completely removed from the splined shaft. Then turn the splined shaft fully counter clock-wise by hand until it stops. Don't worry, it won't fall out. The piston still may not retract perfectly flush after that, but it will be in far enough to get a new set of pads on.
To my knowledge, there were no spare parts or rebuild kits ever produced, but you could source a used caliper from various places such as eBay. Some have also mentioned that a Ural Gear Up model uses the same caliper. Good Luck.
Screenshot 2026-06-20 at 8.48.41 AM.jpgScreenshot 2026-06-20 at 8.49.42 AM.jpg
If you were in the US, I would send one to you, got one in my spare parts box! Snowbelt hit the ball out of the park again like always, got to wind back that shaft!
You might try to contact Can-Am directly in Canada, they might be able to direct you to a supplier close to you or offer suggestions as to what parts or similar parts you may be looking for.
I went through this brake gremlin with a friends RT, Ural is his BEST bet, BRP really wasn't much help! Ural uses the same brake assembly on their bikes today that we use on the older style bike we have! There's really not very much inside that brake assembly that can go wrong, except the screw assembly for the ebrake! Unless you have some scale on the piston that won't go past the seal it should retract in all the way, unless it's hitting the ebrake shaft. My issue with my friend's bike was his master cylinder was out of adjustment enough to make it drag ever so lightly to make it lock up when you didn't want it and when it cooled down it would unlock!!! It was a bear to figure out, but I got to see the inside of that brake assembly firsthand!!:cautious:
As I posted on canamspyderforums.com:
For your brake problems:
Perhaps contact:
pastparts.co.uk
or biggred.co.uk
They deal with obsolete Brembo parts. The former actually does caliper rebuilds for you. You just send them the caliper without the pads and they will send you the rebuilt caliper in return. This would be the safest route as it would be performed by experts using exactly the right components. I know the UK is not in the EU anymore, and that adds a shipping complication, but they do quite a bit of work for EU customers from what I understand.
The second sells parts like seals and pistons, so you might have to do some micrometer measuring etc to order the right parts. The former might be easier but possibly not cheaper with shipping.
They are both experts in Brembo calipers so they may be able to advise which other Brembo calipers the parts kits have in common with the Spyder. Brembo has produced calipers for many, many bike manufacturers since the early 1970's and although the external casting may be unique to Can Am, which I suspect it may not, the internals most likely match whole bunch of calipers they produced over the years.
I think either of these two places are worth an email or telephone call to try and resolve your problem.
Greetings,
I'm from Europe.
Did you ever get it fixed?
