SpyderByter
First of all, :2thumbs: to all you :spyder
wners and modifiers who take the time to give step by step instructions. I refered to Lamonster's before I did my first oil change.
Now, I am trying to adjust the mirrors. I have had no luck getting a hold of Kewlmetal for thier extensions, so I decided to try the 42 cent solution using star washers. In the process, I managed to cross thread the bolt.
I want to take the assembly right off the Spyder, pull the bushing out, and retap the mount. I removed the two 6mm bolts holding it on and gently pulled, hoping to find a connector, but there is no slack. Either way I am going to need that slack if I am able to order the extentions. Before I break something else, I think I should go in there and look.
So what is the process to remove that gauge cluster?
